1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Is the sole purpose of the side terminal to send a full 12 volts to the ignition when the starter switch is pressed? Also from prior posts, there seems to be differing opinions on whether it is needed or not. Comments?
Quote
Yes. It also helps to prevent your alternator from running even after you turn off the ignition by forcing the circuit through a diode.
yes that's what it's for, and yes, it is needed, if ya don't want problems down the road. GM wouldn't have wasted the money to put it there if it wasn't a good thing!
