10 members (J Lucas, Gray_Ghost, Otto Skorzeny, Chuck52, Sjm, rfs56trk, Bill Hanlon, TexasFarmTruck, Guitplayer, 1 invisible),
84
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,259 Posts1,058,305 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | What is the amperage draw of the parasitic drain? It's not uncommon to have a few milliamps of current draw through the voltage regulator. If you've got much more than 1/10 amp (100 MA) that's too much. It would take several weeks to draw the battery down enough to give a starting problem with the tiny parasitic drain of the voltage regulator. Until you get a measurement of parasitic current draw, not voltage, this discussion is meaningless. Jerry
