9 members (Charles in CA, dt235sd, jmoore, Jay R, Southerntruck, Flatblu4748, tclederman, 5cameo8, 1 invisible),
72
3
Mod | | | Forums66 Topics128,128 Posts1,056,683 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | If you needed to buy an engine, then it would probably make more sense to find a 235, but as long as you've already got this engine, I'd say use it. It'll last forever for the amount of driving you plan to do. I'd bet the original was worked a lot harder than that!
