0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I would use the gray silicone on the main caps, Don't put thick coat of it, Just a very thin coat, It will come out and not change the clearance. Rope will seal most anything, Its wider on the contact to the crank. If there was some ware on the crank area where the seal rides on the the crank the rope will fix that,Rope seal needs to be fitted tight and to do it on your back will be not easy but can be done. Trimming the ends of the rope is the key,Sharp razor blade a must, Your engine will turn over harder but once the crank spins it will get better. Getting the seal in the block side is tricky,you can get a tool for this at parts houses,the next best thing to do is loosen all the mains caps so that the crank "drops" a little and slid the rope in and once it's in tighten up the mains before you cut the ends of the rope seal.Take the cap and put it in your vise and install the rope and use a round tool to roll it into the groove and then cut the ends on that,RTV thin coat on the cap and install. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Entire Thread
Sorry, Rear Main Seal question
| AZ59apacheguy | 10/05/2012 7:44 PM |
Re: Sorry, Rear Main Seal question
| baldybenny | 10/05/2012 8:29 PM |
| AZ59apacheguy | 10/05/2012 8:50 PM |
| baldybenny | 10/05/2012 9:12 PM |
| baldybenny | 10/05/2012 11:39 PM |
| AZ59apacheguy | 10/06/2012 12:36 AM |
| baldybenny | 10/06/2012 6:42 AM |
| AZ59apacheguy | 10/06/2012 12:06 PM |
| AZ59apacheguy | 10/06/2012 1:51 PM |
| Pre '68 Dave | 10/06/2012 4:07 PM |
| AZ59apacheguy | 10/06/2012 5:02 PM |
| Pre '68 Dave | 10/06/2012 6:34 PM |
| truckernix | 10/06/2012 9:35 PM |
| Pre '68 Dave | 10/06/2012 9:40 PM |
| AZ59apacheguy | 10/07/2012 1:09 AM |
| Hotrod Lincoln | 10/07/2012 10:03 AM |
| AZ59apacheguy | 10/07/2012 9:25 PM |
| SWEET | 10/07/2012 9:02 AM |
| Joe H | 10/07/2012 10:18 AM |
| truckernix | 10/07/2012 11:02 AM |
| truckernix | 10/07/2012 9:32 PM |
| Joe H | 10/08/2012 10:45 AM |
| AZ59apacheguy | 10/08/2012 3:22 PM |
| Hotrod Lincoln | 10/08/2012 2:22 PM |
| AZ59apacheguy | 10/08/2012 3:18 PM |
| Pre '68 Dave | 10/08/2012 3:21 PM |
| Hotrod Lincoln | 10/08/2012 3:57 PM |
| AZ59apacheguy | 10/08/2012 9:53 PM |
| baldybenny | 10/08/2012 10:10 PM |
| Joe H | 10/09/2012 11:05 AM |
| AZ59apacheguy | 10/10/2012 9:54 PM |
| baldybenny | 10/11/2012 8:46 AM |
| AZ59apacheguy | 10/11/2012 4:13 PM |
| baldybenny | 10/11/2012 11:12 PM | |
