Will do. You know, I did that on the first one with no luck but haven't tried it with this one. I'll admit that this current pump is an older one that came off a running engine so it may have its issues. I just find it ironic that the symptoms are the same.
Just to be safe I placed an order for an extra pump. Not a traditional glass bowl type though. Apparently getting pretty hard to find at the FLAPS now.
