| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87696 04/09/2005 1:58 AM | Joined: Mar 2005 Posts: 49 Apprentice | | Apprentice Joined: Mar 2005 Posts: 49 | I just re-wired the entire truck with a Ez-wiring kit. Relays and all. I had the truck running Sunday and went to town with no problem. Today I started it and Every time I would turn the steering wheel I could here the horn relay making noise. The reason I re-wired the tuck was that the old turn signal flasher got so hot they melted. I must have a short in the steering colum. I shut the truck off and now everything is dead. The battery shows 12 volts but I have no power any where else. I have a fuseble link running to the Alternator and it looks okay but not for sure when they do blow what they look like then. There is a 30 amp large silver fuse on the fuse pannel. Is that the main fuse and if so how do you tell if it's blown.
confused | | |
