7 members (Otto Skorzeny, 3B, Joe H, 49nut, TexasA&M48Truck, 55shaker, 1 invisible),
60
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87091 05/21/2002 5:21 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Check the brake switch on the lower part of the firewall in the engine compartment.It is mounted on the firewall and the brake pedal arm holds it in the off position.They sometimes stick. Pull the brake pedal arm and see if the switch lever moves.If it is stuck, it may be able to work free and losen up so it works. .I have found several that way.
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us. - - Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
