'54 Shop Manual Engine Mounts
< CLICK SHOP MANUAL>Here is the '54 Factory Assembly Manual diagram for rear and front mounts:
< CLICK FAM >You will need the bolt locks for the rear mount. See source in my "saga" below.
Here is my motor mount saga (mostly front mount):
< CLICK SAGA >Buy a Shop Manual, a Factory Assembly Manual, and an Accessories Installation Manual for your truck. Available at most suppliers.
