0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | I am working on installing the engine into my 1954 3100. I have gotten new mounts, I believe that I understand how to install the rears but I want to be sure, they consist of 2 components, a flat mount with a metal side and a rubber side and a "u" shaped mount with a metal side and a rubber side. I believe that they are supposed to sandwich the cross-member with the "u" shaped mount on top and the flat one underneath with the rubber side contacting the cross-member. If anyone would have access to a diagram or know the correct procedure to install the mounts it would be greatly appreciated, Thank you! | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | '54 Shop Manual Engine Mounts < CLICK SHOP MANUAL>Here is the '54 Factory Assembly Manual diagram for rear and front mounts: < CLICK FAM >You will need the bolt locks for the rear mount. See source in my "saga" below. Here is my motor mount saga (mostly front mount): < CLICK SAGA >Buy a Shop Manual, a Factory Assembly Manual, and an Accessories Installation Manual for your truck. Available at most suppliers.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | |
