| | | Forums66 Topics128,121 Posts1,056,328 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | After 500 miles of operation of the rebuilt engine: Warm up the engine, and then run it for 30 minutes at operating temperature. Re-torque the head bolts and the rocker-arm assembly bolts. Set the valve lash. Attach a vacuum gauge to the wiper port on the intake manifold. Attach a tachometer, if you have one. Start the engine and set the idle as close to 500 rpm as you can get it to idle smoothly. Adjust the carburetor mixture screw to obtain maximum vacuum. Adjust the distributor timing to maximum vacuum (or, follow the procedure in the Shop Manual). Adjust the idle to around 2000 rpm. Adjust the timing/distributor to obtain maximum vacuum. Reduce the idle to around 450-500 rpm (manual transmission) or 400-450 (automatic transmission). Check the mixture adjustment again - maximum vacuum. http://www.1954advance-design.com/Documents/Adjustment%20of%20valve%20lash.htmhttp://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0607.htmhttp://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0620.htm | | | |
Entire Thread
235 time, tune, idle questions
| Coachie | 07/10/2012 12:14 AM |
Re: 235 time, tune, idle questions
| tclederman | 07/10/2012 10:12 AM |
| Coachie | 07/10/2012 7:23 PM |
| tclederman | 07/10/2012 7:30 PM |
| Kurt_51carryall | 07/10/2012 7:32 PM |
| Coachie | 07/10/2012 7:51 PM |
| Coachie | 07/10/2012 10:12 PM |
| tclederman | 07/10/2012 10:17 PM |
| Coachie | 07/10/2012 10:35 PM |
| Coachie | 07/11/2012 12:09 AM |
| CASO | 07/11/2012 12:57 AM |
| tclederman | 07/11/2012 9:21 AM |
| Coachie | 07/18/2012 9:23 PM | |
