If I understand you correctly, there are two threaded holes just underneath the valve cover. These holes are for the coil strap. If you are not running the stock coil or strap, put a bolt in the hole with a little teflon to stop the leak.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
