this is the same tip i have in our antique motocycle magazine
only this one is right here on the bolt. check out this tech tip.
only change is to place a washer (if possible) under the nut you weld on :p
http://www.stovebolt.com/techtips/brokenbolt.htm
Jim & Caroline
The highway is for gamblers, better use your good sense."
Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
