| | | Forums66 Topics128,089 Posts1,056,442 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | on my 47 1/2 ton the ebrake, or parking brake, handle is located to the right of the shifter and is a hand operated lever.
On a 48 the same lever is moved to the left of the clutch.
On a 52 you should have a foot operated style that mounts on the left side of the clutch pedal and a hand operated release lever under the dash that would be operated with your fingers.
Look for a set up from a 49 to 54. All the parts should interchange. I will check I should have the pedal and release rod. | | | |
Entire Thread
Emergency Brake question 47, 48 vs 52
| BIGEASY | 03/27/2012 2:43 PM |
Re: Emergency Brake question 47, 48 vs 52
| tclederman | 03/27/2012 3:38 PM |
| 5/8 ton | 03/27/2012 3:45 PM |
| Tom R | 03/27/2012 3:48 PM |
| BIGEASY | 03/27/2012 3:56 PM |
| 5/8 ton | 03/27/2012 4:07 PM |
| BIGEASY | 03/27/2012 6:45 PM |
| Brad Allen | 03/28/2012 1:57 AM |
| BIGEASY | 03/28/2012 4:37 AM |
| tclederman | 03/28/2012 12:07 PM | |
