| | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 110 | Thank you...that seems relatively easy to get it fix...maybe someone can confirm the layout? See if this helps. How I wired mine. Ignore the note at the top, that problem was a bad alternator. My push button is spliced into the wire from the switch to the solenoid, and nothing works but the brake lights unless the key is on. EDIT: Here is how I think you need to correct your diagram. Hopefully somebody will critique it to make sure I am not messing with you. | | |
