1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
So as some you know I did my own electrical system from scratch...I followed most of the '51 truck diagram and added the push button from the '54 diagram since I got stuck on the foot starter that I am not using....
I got my truck running but got a problem with the ignition system and need some advise. I am using the original switch (3 positions) with a push button on the side. The alternator is a one wire and the starter has a "R" and an "S" Terminal...250 motor and all 12 volts....Below is how I wired it...
The problem is the ignition swicth is powered at all times with or without the key...I can push the button and it will turn the starter on all positions of the ignition switch....it won't shut off by turning the key...I do remove the spark plug wire going to the coil to shut it off...HELP!
http://i567.photobucket.com/albums/ss113/jimenezdesigngroup/electrical.jpg
See if this helps. How I wired mine. Ignore the note at the top, that problem was a bad alternator.
My push button is spliced into the wire from the switch to the solenoid, and nothing works but the brake lights unless the key is on.
EDIT: Here is how I think you need to correct your diagram. Hopefully somebody will critique it to make sure I am not messing with you.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thank you...that seems relatively easy to get it fix...maybe someone can confirm the layout?
That correction is exactly the way I would reccomend it. Your original diagram has too many places an unwanted voltage feedback might happen. The 1-wire alternator has its detractors, but other than needing a one-time goose on the throttle after startup, it's the simplest way to make the swap. Good luck on the rewire!
I appreciate everyone's input and will try it this weekend. This is my first electrical system or tryout at any electrical whatsoever but I think with the feedback I can make it work. Thx,
Thank you all. I corrected my electrical as described and it now works perfect..now moving to the turn signals.
thumbs_up glad it worked.
1953 Chevrolet 3600
