2 members (moparguy, 1 invisible),
113
3
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | The only function of the cable on a 350 is for kickdown. Just as the throttle reaches wide open, the cable should reach its full travel. Shift points on a 350 are controlled by the modulator and the governor pressure, which is generated by the speed of the driveshaft. Adjust the kickdown cable to be full forward at wide open throttle and it should function. If it doesn't, there is an internal problem with the kickdown band and/or the servo that applies it. That's overhaul territory! Jerry
