| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82793 09/12/2007 1:26 AM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I dont know that Id put grease in there. Im thinking mine held close to 2 quarts. I filled up the front on mine and then squirted some in the back, I think the rear hole filled up some from it running through the bushing that sits on the ujoint. Do you see a plug about 10" in front of the ujoint plug on top of the tranny? There should be one there that fills the main body of the transmission. Anyways, good luck.
Jeff | | |
