The '50 and up powerglide cars had 3.55 gears, but if you wanted to keep the 6 lug pattern for swapping into a truck you had to use '48 or earlier axles and housing with the 3.55 center section.
There is a tech tip on this. It only applies to '46 or older 1/2 ton.
Steve
'49 3800
'52 3600
'57 3100
