| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Check the head with a straight edge, you should be able see any warp, then check the headers. IF your headers are like the two that I have, the pipe has been welded to the flange on the head side. You can flatten out the welds some depending on how good you think the weld penetration is. Use two gaskets and hi temp RTV on all three surface. Torque down, run to a good temp, re-torque. That should help. The next set of headers I get will be Fenton.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
