2 members (tclederman, Phak1), 37 guests, and 1 robot.
Topics128,090
Posts1,056,031
Members48,433
#825311 02/12/2012 2:55 AM
Hi All, I have a 1970 c 50 with 292 and have installed aluminum intake and headers. The Headers keep blowing gasket and the shop says the head is warped. It only has 8000 miles on original engine. What do you think.
3B Offline
Hy Crockbuyer, I would think it's the header that's warped rather than the head.
Check the head with a straight edge, you should be able see any warp, then check the headers. IF your headers are like the two that I have, the pipe has been welded to the flange on the head side. You can flatten out the welds some depending on how good you think the weld penetration is. Use two gaskets and hi temp RTV on all three surface. Torque down, run to a good temp, re-torque. That should help. The next set of headers I get will be Fenton.
Larry
I don't own a vehicle that isn't old enough to drink.
Thanks I did not see how a huge piece of cast iorn could be warped and thanks for the info i will tell the shop what to do, Tony
http://i1193.photobucket.com/albums/aa359/crockbuyer/031.jpg
It is not that the head warps but that it rusts away around the exhaust ports.
My Blog
Riding in the Passing Lane
292 engines run extremly hot exhaust systems when used in the larger trucks. We contantly replaced gaskets & manifolds back when I worked on fleets of Step Vans. There used to be available a stainless steel gasket for them but they discontinued them many years ago. I would check & see if someone has a solid copper gasket available for it. Or possibly running without a gasket on the ex. ports like the V-8s. Make sure there is as little back pressure as possible. Low restrictive mufflers. That business about the head being warped is a cop out.
1972 Chevy c10 Cheyenne Super
