| | | Forums66 Topics128,125 Posts1,056,338 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I haven’t got it up on the bench yet Wayne, and no, I haven’t read what Charlie posted to the tech section. I’ll print it out and put it with the switch for when I get to it. Looks to be to much for me to swallow right now. And yes, that is the switch in one of the pictures that you‘ve link us to.
Gave up on the patent search Lonnie, 30 min. was enough chasing around. But, the link to the thread were fonz8261 mentioned the ‘51 accessory installation manual struck home, so I dug mine out and it does show all I need to know.
This was the switch for the passenger car I don’t know if it was the one the was used on the trucks but it looks like it will work on the truck steering wheel so I’m gonna use it. It is a seven wire unit just like the Signal Stat unit only this is a genuine GM accessory so it should be correct if nothing else, it will be period correct.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
Entire Thread
Guide, but not a hunting guide.
| Denny Graham | 01/06/2012 10:56 AM |
Re: Guide, but not a hunting guide.
| SimS | 01/06/2012 11:36 AM |
| Denny Graham | 01/06/2012 1:01 PM |
| Wayne67vert | 01/06/2012 2:17 PM |
| LonnieC | 01/06/2012 5:09 PM |
| Denny Graham | 01/07/2012 1:35 AM |
| Brad Allen | 01/11/2012 2:11 PM |
| tclederman | 01/11/2012 3:23 PM |
| Brad Allen | 01/11/2012 7:51 PM |
| Denny Graham | 01/12/2012 1:57 AM |
| tclederman | 01/12/2012 3:49 AM |
| Denny Graham | 01/12/2012 1:36 PM |
| LonnieC | 01/12/2012 1:56 PM |
| Denny Graham | 01/12/2012 9:35 PM |
| LonnieC | 01/13/2012 4:13 PM |
| Mr. Lang | 01/13/2012 4:23 PM |
| Denny Graham | 01/13/2012 11:31 PM |
| Brad Allen | 01/14/2012 12:14 AM |
| Denny Graham | 01/14/2012 2:05 AM |
| Brad Allen | 01/15/2012 12:32 AM |
| Denny Graham | 01/15/2012 1:55 AM |
| Mr. Lang | 01/15/2012 2:22 AM | |
