1 members (Hotrod Lincoln),
76
8
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Did you try Tiny's method. I've had some very hard to get off and usually, tension with the puller, someone sitting in the seat with knees up against steering wheel real hard and then a big whack with the hammer and it would pop up and off......be sure to run the nut down on the shaft till its even so that you don't ruin the threads.
..it might help to soak it overnight with some Kroil. Let us know how you make out. | | |
