| | | Forums66 Topics128,154 Posts1,056,837 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | No experience with the 46's but maybe this will help.
First off is your floor ONE piece plywood or is it boards?? (My52 is one piece plywood but I don't think yours is) If so, the plywood can be special ordered as bigger than 4/8. I do not know of a kit for what you want even though I know they have kits for pickups. I'd suggest calling Mar-K. They're known for their quality and American made! They can probably help with the "placement". Give them a call and let them know your a stovebolter. If they can help they will..... or you may also post in the section for truck bed section and someone from Mar-K may chime in. They keep a check there.
Not sure which metal trim pieces your looking for but if its the metal strips to go in the floor I feel sure you can get those. Again, I refer you to Mar-K.... but you could also make a few calls to other vendors which are listed in the Links section here on the bolt. If its specific trim pieces you may try the Parts Wanted Forum in the Swap Meet section.
Good luck. I love the windows on the back doors of the art deco style....hopefully something I've said will help?
