1 members (Gdads51),
57
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is what a complete set looks like: http://good-times.webshots.com/photo/2235943390102454676FUuGUvThe shims can go to the frame or the body some have none at all. I have seen some trucks that have as many as five shims. The threaded lock plates go inside the cab to prevent the bolts from pulling through the sheet metal. If you install new rubbers in them and clean them up they work as good as new. | | |
