7 members (3B, Bill Hanlon, TooMany2count, Otto Skorzeny, Peggy M, GDW, 1 invisible),
114
2
Mod | | | Forums66 Topics128,139 Posts1,056,460 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79205 06/25/2007 8:19 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | dublenaught,
As you assemble the engine and get it ready to run, you can adjust the valves cold if you add .005 thousandths to the book HOT settings. This will get you very close and you can run your engine without fear of burning a valve.
If your cam requires a HOT setting of .006 on the intake, set it at .010 or .011 cold...same with the exhaust lash.
Have you followed the threads on cam break-in procedures and motor oil additives. Although this doesn't' seem to be critical for stock cam grinds and stock valve train components, it sure wouldn't hurt to give it a quick peek and maybe choose your initial oil fill based on what you find.
Stuart | | |
