7 members (Gray_Ghost, cmayna, Rusty Rod, TUTS 59, Rusty Heaps, 49choptop, treegrower),
105
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,067 Posts1,055,877 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78438 06/05/2007 1:28 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Yes,
1. Mark the driveshaft so it goes together the same way it came off because it is balanced (or should be). I usually mark it on the knuckles with a punch, or chalk works. Just don't rub it off. Take out the hanger bearing bolts. 2. remove the bearings from the rear end. 3. Tape up the bearings on the rear knuckle so they don't fall off (unless you ar replacing them). 4. The rear shaft will pull off the center near the hanger now, or you can pull the whole thing out of the tranny.
Oil will come out of the tranny so get a catch pan. Also a good time to replace the rear tranny seal and the driveshaft knuckles. Check the tranny and rear end oil levels when reassembled. | | |
