| | | Forums66 Topics128,093 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78234 05/30/2007 3:54 PM | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | That's classic over-carburetion. If the engine isn't able to accelerate when you dump the throttle, the venturi velocity slows down, and you lose the vacuum that keeps the fuel flowing through the carb. You need to go to some sort of progressive linkage that allows one carb to open only at higher RPM, or find smaller-bore carbs that won't lose venturi velocity when both are open at low speed. It doesn't matter how much fuel the pump can supply, if the gas can't make it from the float bowl to the air stream in the venturi. Make sure the float level is as high as possible without flooding, as the same symptoms can result from even a slightly low float setting. Jerry
