8 members (C10 - C90 Bill, Donf, DoubleB, Otto Skorzeny, Gdads51, Hanks custodian, Forty9, 1 invisible),
40
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,020 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78232 05/30/2007 5:22 AM | Joined: Jul 2006 Posts: 9 Junior Member | | Junior Member Joined: Jul 2006 Posts: 9 | Hello, I have a 235 w/dual holleys and langdons hei distributor. I thought that everything was working perfect until I took it out and opened it up. 1st and 2nd it purred went to 3rd and it just bogged down. I pulled over it was running and again in first and second no problem. Only in third and full throttle it bogs out. Any thoughts?
Thanks.....jeff | | |
#78233 05/30/2007 6:10 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy a19593200, How is your fuel pump, able to keep up with two carbs? Are your float levels set correctly? Hope that helps. | | |
#78234 05/30/2007 3:54 PM | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | That's classic over-carburetion. If the engine isn't able to accelerate when you dump the throttle, the venturi velocity slows down, and you lose the vacuum that keeps the fuel flowing through the carb. You need to go to some sort of progressive linkage that allows one carb to open only at higher RPM, or find smaller-bore carbs that won't lose venturi velocity when both are open at low speed. It doesn't matter how much fuel the pump can supply, if the gas can't make it from the float bowl to the air stream in the venturi. Make sure the float level is as high as possible without flooding, as the same symptoms can result from even a slightly low float setting. Jerry
#78235 05/30/2007 4:39 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just curious...are you using Holley/Webers or some other configuration. I was told that the Holley/Weber carb was a good single carb for the stock cammed 235 and that the Carter/Weber, with a lower cfm, was recommended for use in pairs on a stockish 235.
I'm currently running the C/W pair on my fresh 235 and haven't had any problem when the secondaries kick in. I put on a fuel pressure regulator and gauge and found that 3-3.5 psi made my C/W's happier than full pump pressure. H.R.L has hit it on the button....a lot depends on the total setup and it just sounds like maybe if you're running the H/W's you're just over-carbed.
Dave | | |
