| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78060 05/26/2007 9:51 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | For an engine to run you need air, fuel, compression and proper timing. If you know for sure you have spark and fuel, check timing. I'm assuming it has compression since it's trying to start. It may be low since the cylinders are getting washed from the fuel being pumped through it. Good luck and keep us posted to what the problem was, Scott
PS. can you keep it running with carb spray? If so, look at having a fuel delivery problem. | | | |
Entire Thread
Okay, some progress,engine question
| Purney | 05/26/2007 8:19 PM |
Re: Okay, some progress,engine question
| bigbadswingdaddy | 05/26/2007 8:58 PM |
| 48bigtrucks | 05/26/2007 9:51 PM |
| 1958GMCnut | 05/27/2007 3:07 AM |
| Purney | 05/27/2007 8:49 PM | |
