| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Assuming you have the original Rochester carb:
Q-Jets as a general rule have no personality. They either work or they don't. Also, the engine should run BETTER, not worse, under damp cooler conditions (more oxygen).
Possibilities:
Partially clogged fuel filter Partially clogged fuel sock in tank Ignition Icing (rare with a large 8, but it does occur, particularly if headers and/or aftermarket aircleaner)
If the "dry gas" (alcohol) is helping, I would try a tank of gasoline from a different source. Here is Missouri the humidity often exceeds the temperature, and I have not ever needed (in fact avoid) the alcohol in over 40 years of driving.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | |
Entire Thread
A Problem, I Think its the Carb
| Salinaz | 03/22/2004 11:43 AM |
Re: A Problem, I Think its the Carb
| Alan Horvath | 03/22/2004 1:52 PM |
| carbking | 03/22/2004 2:18 PM |
| Salinaz | 03/22/2004 11:13 PM |
| arnswine... | 03/23/2004 1:12 AM |
| Salinaz | 03/27/2004 10:58 AM |
| ChevyAsylum | 03/27/2004 4:05 PM |
| gusc | 03/29/2004 6:02 AM |
| Rickcapt | 03/30/2004 1:24 AM |
| Salinaz | 04/01/2004 9:10 PM |
| Alan Horvath | 04/01/2004 10:05 PM |
| Salinaz | 04/04/2004 11:04 AM |
| gusc | 04/04/2004 9:33 PM |
| Alan Horvath | 04/04/2004 10:02 PM |
| Mechainiac | 04/05/2004 12:40 AM |
| Salinaz | 04/05/2004 10:53 AM | |
