7 members (Gdads51, 55shaker, greenie-reddy, UtahYork, 3B, Peggy M, joe apple),
125
3
Mod | | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | I have been running the truck with the pretronix with the ballast resistor. You can run it with out the resistor if you use a coil with internal resistor built in and by pass the resistor. I went ahead and used the original type coil and resistor because I already had a coil on the truck that needed a external resistor. The truck ran great up until recently. And I'm pretty sure that Joker is right about something being wrong in the ignition wiring. it is probably a easy fix once I find where the circuit is broke at. I'n just about recovered from my hospital stay. So I will have the truck up and running. I will post what the problem was after I fix it. That way if someone else has the same problem hopefully it will help them out.
Entire Thread
question about starting issue, ballast resistor??
| tracern1 | 08/16/2011 1:09 AM |
Re: question about starting issue, ballast resistor??
| squeeze | 08/16/2011 1:40 AM |
| tracern1 | 08/16/2011 1:51 AM |
| squeeze | 08/16/2011 2:23 AM |
| tracern1 | 08/16/2011 4:15 PM |
| tracern1 | 08/16/2011 8:58 PM |
| 3B | 08/17/2011 5:12 AM |
| tracern1 | 08/17/2011 1:34 PM |
| rfs56trk | 08/19/2011 4:29 PM |
| joker | 08/19/2011 4:55 PM |
| tracern1 | 08/19/2011 6:01 PM |
| tracern1 | 08/20/2011 3:09 PM |
| rfs56trk | 08/20/2011 3:56 PM |
| squeeze | 08/20/2011 4:14 PM |
| tracern1 | 08/20/2011 7:21 PM |
| squeeze | 08/20/2011 7:25 PM |
| tracern1 | 08/20/2011 7:48 PM |
| rfs56trk | 08/21/2011 4:30 PM |
| Cletis | 08/19/2011 6:25 PM |
| joker | 08/19/2011 6:43 PM |
| tracern1 | 08/19/2011 10:26 PM |
| joker | 08/19/2011 10:41 PM |
| amabolter | 08/20/2011 12:11 AM |
| joker | 08/20/2011 12:52 AM |
| amabolter | 08/20/2011 2:36 AM |
| tracern1 | 08/20/2011 3:15 AM | |
