Go to www.gregsonline.com and get a manual on how to work on your truck. It's always the best place to start.
You will most likely need to replace seals, wheel cylinders, brake lines (hard and flexible), master cylinder as well as shoes. The master cylinder may be an expensive piece on that truck. The rear axle seals would be a good thing to replace.
One thing leads to another.
