Looks can be deceiving. For good or bad. My personal experience is yes, most bellhousings and especially the mounts are nasty most of the time. I can't count how many times I've had to dig the grease and dirt off to find the bolts and specially the mounts. I'd clean them up real good and if the rubber seems to still be bonded good I'd use them.
If its peace of mind you want and you have the cash then I'd spring for new ones.
On the other hand these are not hard to change if one ever does break.
It boils down to your decision as your the one that can see it.
