| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | I'm gonna try some J-B weld first and see what happens I'd suggest using something a little more flexible than J-B Weld. Try some Marine-Tex sealer, after getting the area around the rivets beadblasted to remove any paint that would interfere with the bonding. Marine-Tex stays slightly flexible, and it is used as a thread sealer on some pretty high-pressure applications on inboard boat cooling systems, bilge pumps, etc. J-B Weld would probably crack and fall off the surface if there's any movement at all between the wheel and the rivets. Jerry
Entire Thread
Wheel issues, Help!
| Tate | 06/10/2011 12:50 AM |
Re: Wheel issues, Help!
| DrewP | 06/10/2011 12:56 AM |
| LONGBOX55 | 06/10/2011 2:29 AM |
| tclederman | 06/10/2011 3:07 AM |
| LONGBOX55 | 06/10/2011 3:30 AM |
| Tate | 06/11/2011 1:34 AM |
| Roy Rodgers | 06/11/2011 2:48 AM |
| 40casey | 06/11/2011 2:56 AM |
| LONGBOX55 | 06/11/2011 3:07 AM |
| WE b OLD | 06/11/2011 2:17 PM |
| tclederman | 06/11/2011 3:34 PM |
| BC52 | 06/11/2011 3:52 PM |
| squeeze | 06/11/2011 4:34 PM |
| tclederman | 06/11/2011 6:34 PM |
| squeeze | 06/11/2011 6:58 PM |
| Tate | 06/12/2011 7:34 PM |
| Hotrod Lincoln | 06/12/2011 10:22 PM |
| SC3100 | 06/14/2011 11:43 AM |
| Tate | 06/17/2011 1:25 AM |
| Jianis | 06/12/2011 7:50 PM | |
