0 members (),
94
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | As a general rule paint is only a pigmented adhesive. It should make no difference where it's the colored base or the clear coat. Sanding with the correct grit paper should allow you to re-shoot your jams. Having said that, my experience with modern materials is limited so if I'm full of beans someone will point it out.
