| | | Forums66 Topics128,051 Posts1,055,705 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Even grinding the hot spots doesn't soften them, so the problem just reappears in a short time. Hot spots are actually football-shaped, so the small area that shows up as a hard, high spot that a tungsten carbide bit won't cut during drum-turning operations will require a great deal of machining to eliminate it altogether. I've encountered the same problem during flywheel grinding when doing a clutch job. Jerry
