John,
I have poured gas down the carb, both a little and a bit more, but still nothing.
I have not done a compression test as i was just assuming that since im not getting spark off of my block when i hold the spark plug 1/4 inch away, that there is something stopping the ground.
Is there anyway to tell for sure if my truck is positive or negative ground? i currently have it negatively ground and my lights work, heater works, and horn works...
It's running off of a 6 volt, i replaced the 6 volt coil when i changed plugs and distributor ect.
Since the negative ground is grounded onto my starter could there be some sort of interference between the starter and block which is only allowing the starter to be grounded, not the block?
