.....if time is no problem you may want to pull the drums back off and look at the shoes. There is a chance the "ends" of the shoe lininig is dragging before the rest of the shoes. You should be able to tell. With the quality we get these days I'd suggest "rounding" the end of the square cut on the shoes just a bit to make sure that the ends aren't whats causing the problem.
Worth a peek isn't it?
