| | | Forums66 Topics128,274 Posts1,058,425 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74490 05/28/2007 8:28 AM | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | EUREKA!!!I FOUND THE PROBLEM???? Today I pulled the 235 out of the truck that was rebuilt a long time ago, but never ran, It ran 3 minutes with good oil pressure with gas being fed into the carb to prime fuel pump, engine slowed down and stopped--LOCKED UP TIGHT! Pulled oilpan to find...#5 conrod bearing scored 3/4 way around with a Piece of Castiron burr embeded into the crank journal, Crank was Balanced and balanced grinding areas have burrs, I suspect a piece of cast iron went thru the oil pump into the oil gallery and stopped at #5 conrod shell. :mad: As machine shop no longer in existance, I will try to clean up crank burr, replace conrod shells, reinstall with crossed fingers and hope for the best.. otherwise it means a re/re of the crank for further machining and cleaning....Any suggestions would be appreciated. Dave  | | | |
Entire Thread
235 6 cyl, ran 3 min, siezed
| 1958GMCnut | 03/08/2007 7:03 AM |
Re: 235 6 cyl, ran 3 min, siezed
| 3B | 03/08/2007 7:19 AM |
| 1958GMCnut | 03/08/2007 8:09 AM |
| meansam | 03/08/2007 12:40 PM |
| Grigg | 03/08/2007 12:43 PM |
| Fla54Chevy3100 | 03/08/2007 2:56 PM |
| 64fleetside | 03/08/2007 3:34 PM |
| atomarc | 03/08/2007 9:35 PM |
| 64fleetside | 03/08/2007 9:42 PM |
| Grigg | 03/08/2007 9:49 PM |
| 1958GMCnut | 03/09/2007 12:44 AM |
| Leo | 03/09/2007 2:35 AM |
| 48bigtrucks | 03/09/2007 3:36 AM |
| down2sea | 03/09/2007 3:45 AM |
| rasman57 | 03/09/2007 4:03 AM |
| 32fire2 | 03/09/2007 11:51 AM |
| meansam | 03/11/2007 1:09 PM |
| WE b OLD | 03/11/2007 8:11 PM |
| project 39 | 03/11/2007 10:04 PM |
| 1958GMCnut | 03/18/2007 3:11 PM |
| Darin367 | 03/18/2007 3:46 PM |
| RAC1812 | 03/19/2007 4:54 PM |
| Stovebold | 03/22/2007 12:01 AM |
| Hot Rod Dad | 03/22/2007 2:46 AM |
| Hot Rod Dad | 03/22/2007 2:48 AM |
| chiphead | 03/22/2007 4:40 AM |
| 1958GMCnut | 03/22/2007 8:12 AM |
| 1958GMCnut | 03/22/2007 8:14 AM |
| wick37 | 03/22/2007 1:45 PM |
| 1958GMCnut | 05/28/2007 8:28 AM |
| Roy Rodgers | 05/28/2007 12:50 PM |
| Fla54Chevy3100 | 05/28/2007 2:04 PM |
| Hotrod Lincoln | 05/28/2007 4:37 PM |
| Grigg | 05/28/2007 4:47 PM |
| 1958GMCnut | 06/02/2007 5:44 AM |
| SW_Radial | 06/02/2007 5:59 AM |
| 1958GMCnut | 06/04/2007 4:17 AM |
| 1958GMCnut | 06/05/2007 5:21 AM | |
