I should also mention that the cost for using the tool I mentioned above is FREE!!!! You put a deposit on a credit card for the cost of the tool, and it is returned to the card when you return the tool.
Do your self a favor and use the tool that was designed to do the job. Not only will it be done correctly, but will be easy.
