53,
I put them around the doors themselves and down the stationary door.Get you 2 tubes of 3M weatherstrip and some tape to help hold stuff still.Put glue on both surfaces and let it set a few miniutes.You will have to be creative at the top and bottom to make a good seal in the middle.You don't need the widelace.The rubber you need is slitly smaller than the side doors and shaped like a tooth laying sideways.I can email photos.Hope this helps.
Sully
