| | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69856 12/11/2006 8:19 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The violet wire should go from the starter side terminal to the + side of the coil so that's wrong but it should run without that anyway. Turn the key on and see if a bulb will light when grounded and touching the coil + terminal. Here's a 1955 wiring diagram that should be close enough. http://chevy.tocmp.com/1955truck2shop/55ctsm1202.htm Try to post in the electrical forum for this stuff and going thru the archives there should help you get every wire in it's place. Good luck. Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
