| | | Forums66 Topics128,077 Posts1,056,012 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | If your rear Burb fenders are otherwise in good shape I would definitely repair the edges near the bolt holes. If these areas are rusted away then patch them with either metal or fiberglass as you've noted.
If they are just "thin" then reinforce those areas with Fiberglass; right over the holes and re-drill the holes. Treating thin or rusted areas with POR 15 is a good plan pre or post repairs as necessary.
Wrestling with aftermarket reproduction Panel/Burb fenders is an exercise in frustration so keep your rears metal! IMHO Squire | | |
