| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Any machinist with more than three brain cells to rub together could fit a small block V-8 oil pump to a 235 in a matter of hours. It would be very simple to adapt the mounting flange and drive shaft with a custom-made bracket. I doubt if it would even be necessary to modify the oil pan. It's just not necessary to go to that extreme if you've got a stock pump in good condition and a properly-clearanced engine. Jerry
