Any recommendations for companies who make adapters so I can mount my stock 6 lug rims to a later 5 lug rear.
I have an S 10 rear end on hand now. It is said that it is supposed to fit under my 37 1/2ton but it sure looks to be a tight fit (by measurements) Will be doing more dry fitting and measuring, but it sure looks tight.
If it does fit, I am guessing the adapters will push the wheels more to the correct spot in the fender wells.?
:confused: Any feedback on this set up would be helpful. My stock rear end measures 54" backing plate to backing plate, with a measurement of 41" center of spring perch to center of spring perch. The S 10 measures 47 1/2" backing plate to backing plate.
1937 Chevy 1/2-Ton
