| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68372 11/09/2006 2:46 AM | Joined: Nov 2006 Posts: 25 Junior Member | | Junior Member Joined: Nov 2006 Posts: 25 | Gave up on 1966 250. Now just curious. Engine smoked bad. New head. Let it idle for an hour. Kept right on smoking till I saw oil dripping out of exhaust pipe. Gave up took off intake exhaust manifold. Lots of oil in both the manifold and head ports. Number two intake had an actual puddle of oil completely surrounding the valve.
Can that much oil come down the guide????
PS. The motor smoked before I had the head rebuilt. When I took the head off to get rebuilt I noticed oil in the intake and exhaust. In other words it is doing the same before and after the rebuilt head. So I am guessing the rings are bad even though I had 140 plus compression.
Is it possible to get oil in the intake from bad rings?????
Thanks for any input. I will update the condition of the rings when I pull the pistons. | | |
