Any reason you couldn't use Velcro (hook & loop)? Put enough around the edge of the panel, I gotta believe it would stay. Thinking about doing it with mine unless someone tells me they've tried it unsuccessfully.
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
