12 members (gswbbc, Gdads51, Scott, frogfarmer, panel fan, FAST55, JW51, Wayne67vert, Lightholder's Dad, 48jim1ton, tclederman, 1 invisible),
70
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....if you can get the wing vent glass out easy I would say replace it with the assembly still in the door......just my .02 cents. Fill the glass frame with Black ADHESIVE silicone. Cut the tube so it will put out a big enough line to fill the vent window frame. Then slide in the new glass, close window and pull the glass back a little so its a tight fit, then lock the window in place until the next day. Then trim off the excess and see what a good job you have done. Don't even try to mess with the black mess until after its dried or you will have a mess. It will Scrape off the glass easy. | | |
