| | | Forums66 Topics128,132 Posts1,056,383 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | The adapter plate you're hearing about is used to relocate the pump higher on the block, and it covers the original hole in the 235 block. It allows the earlier style pump for the 216 and splasher 235 to be installed, which does not have the impeller that extends into the block. The early pump has a rear cover plate, and the impeller is fully contained by the pump housing. The harmonic balancer swap is required because the earlier pump uses a wider belt. It will also be necessary to swap to a wider generator pulley. Jerry
