7 members (Shaffer's1950, Southerntruck, Gdads51, John Dlugos, FAST55, TexasJim50, F100Ranger),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,378 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,813 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,813 | The adapter plate you're hearing about is used to relocate the pump higher on the block, and it covers the original hole in the 235 block. It allows the earlier style pump for the 216 and splasher 235 to be installed, which does not have the impeller that extends into the block. The early pump has a rear cover plate, and the impeller is fully contained by the pump housing. The harmonic balancer swap is required because the earlier pump uses a wider belt. It will also be necessary to swap to a wider generator pulley. Jerry
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | A water pump from a 53-54/55.1 235 should have a 3/8" pulley. Parts Manual Link. Doug's images show the late model block and water pump. The adapters to use the earlier water pumps on the late model block are usually available on ebay from pre68dave, a good 'bolter. Hoyt | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I just recently installed pre68dave's adapter on the '55 235 I installed in my '50 3100. If you follow Dave's instructions, you will have no problem installing it with the correct early style pump. Using hand tools, it took me about an hour. Just pay attention when you are drilling the 2 additional mounting holes you need so as not to drill too deep.
Drew
| | | | | Joined: Mar 2009 Posts: 75 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 75 | Thanks Drew,
It's nice to hear that it worked out well. What were your overheating problems/symptoms before the plate? My truck overheats in about a mile or so of stop and go.
and, I'm still trying to determine my harmonic balancer pully situation - it is 6 3/4" x 5/8" O.D. but the belt is actually 1/2" wide. Did you use the '55 balancer and was it of similar dimensions?
thanks,
Doug
